FAQ: Test sources
FAQ: Test sources
Test sources:
My kit will not respond to bananas, at least not in an obvious way. I believe that a more sensitive pancake-style detector is required - bananas just aren't that radioactive. It may be possible to see a small signature using a large number of bananas (I hear some types are more radioactive than others) and a long sample time (extended data logging). It will not be an easy measurement.
Camping mantles made in the last several years are NOT radioactive. If you purchase a mantle from a sporting goods store, Target, etc it will NOT be radioactive, I have checked!
Also, my geiger kit will not detect much radioactivity from a smoke detector, so that is also not a good test source (and disassembly of a smoke detector is dangerous). The results will be disappointing, anyway.
Good test sources include:
- some granite countertops
- vaseline (depression) glass, available on eBay as uranium marbles
- orange/red Fiestware produced before the 1960s (eBay)
- old watches with Radium dials (probably pre-1960s, ordinary glow in the dark watches won't work)
- uranium or other radioactive ore samples (eBay, United Nuclear)
- thoriated welding rods (welding supply store, eBay)
- old camping mantles containing Thorium (eBay)
- some camera lenses with thoriated optics, but these are rare (maybe available from antique camera dealers or eBay)
More info here: http://mightyohm.com/blog/2012/02/feed- ... t-sources/
wkhilarides
Re: FAQ: Test sources
Post by wkhilarides »
I'm a good source! I had a Prostate Brachytherapy implant two weeks ago. They implanted 97 Ceramic Cesium 131 seeds in my prostate. I need to stay away from children, and can't sleep n the same bed with my wife. I am currently emitting 120,000 CPM, but the radiation falls exponentially with distance from my prostate radiation (CPM) = 10890*e^(-0.281*Distance(in)). I'm not sure of the calibration, since I have such a strong impact on the readings. We have red FiestaWare plate that reads about 12,000 CPM. 131Cs has a half life of 9.7 days. and an average Photon energy of 29 keV. I will see if the the radiation is reduced by half nine days from now.
Does the device send one data point per second? It looks like uSv/hr = 0.0059* CPS.
This is great! Thanks
Kurt H.
Kurt,
Wow, 120,000 CPM! :o
Yes, the serial port sends one update every second.
thegrendel
Post by thegrendel »
Another good radioactive source:
Certain of the "Quantum Scalar Energy Pendants" available
on eBay and from various other sources. I got a "FusionExcel"
model, complete with Authenticity Card for $6.99 (shipping included)
on eBay a few months back. Close up to an SBM-20 tube it reads
400 cpm (normal background here is 20).
Google "quantum scalar pendant radioactive" or see:
http://www.youtube.com/watch?v=wfGKJK8Zgtc
for example.
And by the way, my QSE Pendant was one of the first things
I used as a check source with the MightyOhm geiger kit I just
finished building. Beep-beep-beep, flash-flash-flash.
I haven't seen this pendant before. 400 cpm is not bad.
Let me know if you find any truth to the "healing properties". :lol:
killswitch
Post by killswitch »
Hi
Another test source i found that works is fertilizer. Ive got a bag of NPK powder mix and the K in it gives off about 80CPM's.
A pure bag of K before mixing will probably give off more.
I'm guessing this is due to naturally occurring K40, the same reason that salt substitute (and people) are slightly radioactive.
dmainmon
Post by dmainmon »
wkhilarides wrote: It looks like uSv/hr = 0.0059* CPS.
Is this the equation used for uSv/hr ?
The scale factor used in the code is 0.0057.
