Box online, but do not play
shell3000
Post by shell3000 »
my OpenWRT-Installation on the Asus WL-520GU was successfull (only LAN Setup)
but the the mpc-status is always on 0:00.
root@OpenWrt:~# mpc play
http://80.86.106.136:8000
[playing] #3/3   0:00/0:00 (100%)
volume:100%   repeat: off   random: off
root@OpenWrt:~# mpc stats
Artists:      0
Albums:       0
Songs:        0
Play Time:    0 days, 0:00:00
Uptime:       0 days, 13:56:40
DB Updated:   Sat Jan  1 00:56:11 2000
DB Play Time: 0 days, 0:00:00
Maybe a problem with the connected USB-Device? I use a Griffin PowerWave, the opposite of a small and cheap Audio-Adapter. It`s set as OSS-Device.
Thanks for reply,
shell
Shoutcast-Installation on Mac OS X:
http://skynet.di.hs-wismar.de/?p=45
Re: Box online, but do not play
It could be an issue with the audio device, or the mpd audio settings. Have you tried several mp3 audio streams?
Does /dev/sound/dsp exist? If you do something like "cat /bin/ls > /dev/sound/dsp" do you hear static on the audio output?
jaycollett
Post by jaycollett »
I had a similar problem, couldn't figure it out until I noticed that my wireless LED wasn't blinking...it couldn't connect to the slay radio stream. I found a different one and it worked like a charm. Seems like for me, at least, I can't connect to the example radio stream. Try a few others that you know work....
shell3000
Post by shell3000 »
I tried several streams, nothing works.
root@OpenWrt:/dev/sound# ls -als
   0 drwxr-xr-x    1 root     root            0 Jan  1  1970 .
   0 drwxr-xr-x    1 root     root            0 Jan  1  1970 ..
   0 crw-------    1 root     root      14,   3 Jan  1  1970 dsp
   0 crw-------    1 root     root      14,   0 Jan  1  1970 mixer
   0 crw-------    1 root     root      14,  16 Jan  1  1970 mixer1
DSP exist, but i get an error after your tip:
root@OpenWrt:~# cat /bin/ls > /dev/sound/dsp
-ash: cannot create /dev/sound/dsp: Interrupted system call
Nothing to hear. I will try the WLAN-Setup, but i suggest
also a problem with the Audio-Adapter.
Next step is to a buy a new one.
shell
I have had good luck with the SYBA USB-audio adapter, and zero experience with others. Based on what I have seen on the forums, picking a good alternative audio adapter is tricky. If possible, find the SYBA adapter that I used.
