Hello.
I'm in the process of building the radio by this project. But I do not want to build it based on the router but the motherboard from the notebook. For now, I ran the display and tuning. For testing I use Debian (for now)
I have a problem with the speed performance of the script display2.sh (or interface.sh - I'm not sure). Script runs very slowly - sends data TITLE, NAME to display approximately every 2 minutes. I do not know where the problem is.
Once unlocked display echoes on the local console is the same.
Sorry for my English.
Problem with display.sh ?
Re: Problem with display.sh ?
Wow, interesting problem! I would try to get the display2.sh script working by itself first.
You will need to uncomment the #stty line towards the top of the script (normally interface.sh takes care of this).
If the updates are still slow, try adding some echo statements at various points in the script to see if it is stalling in a particular place.
It might be interesting to see if "sleep 1" waits for one second, as intended, or some other amount on your system.
It looks that the "sleep 1" in my case means 1 minute. Data is sent exactly once every minute. The documentation shows that the default is 1 second, I do not understand how this change.
I hope that the target system (openwrt) will be fine.
Currently I'm trying to compile openwrt for x86, unfortunately, ineffective.
I find this very puzzling.
If you execute "sleep 1" from your Debian shell, how long does it take for the command to run?
From the Debian manual page:
SLEEP(1) User Commands SLEEP(1)
NAME
sleep - delay for a specified amount of time
SYNOPSIS
sleep NUMBER[SUFFIX]...
sleep OPTION
DESCRIPTION
Pause for NUMBER seconds. SUFFIX may be `s' for seconds (the default),
`m' for minutes, `h' for hours or `d' for days. Unlike most implemen-
tations that require NUMBER be an integer, here NUMBER may be an arbi-
trary floating point number. Given two or more arguments, pause for
the amount of time specified by the sum of their values.
--help display this help and exit
--version
output version information and exit
AUTHOR
Written by Jim Meyering and Paul Eggert.
REPORTING BUGS
Report bugs to <bug-coreutils@gnu.org>.
COPYRIGHT
Copyright (C) 2008 Free Software Foundation, Inc. License GPLv3+: GNU
GPL version 3 or later <http://gnu.org/licenses/gpl.html>
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law.
SEE ALSO
sleep(3)
The full documentation for sleep is maintained as a Texinfo manual. If
the info and sleep programs are properly installed at your site, the
command
info coreutils 'sleep invocation'
should give you access to the complete manual.
GNU coreutils 6.10 January 2008 SLEEP(1)
It's strange, "sleep 1" is performed exactly in the 1s. Appropriately such as "sleep 5" stops for 5 seconds, I'm confused ... It seems that the command "sleep" is responding properly.
