troubleshooting lan connection
eli2k
Post by eli2k »
I'm trying to do part 8 right now, connected a cross-over cable, and modified the network config file:
#option type	bridge
option ifname	"eth0.0"
option proto	static
option ipaddr	192.168.1.1
option netmask	255.255.255.0
When I try to telnet to 192.168.1.1, it doesn't seem to work, and if I telnet over the wireless, that doesn't work either. So I had to go back to the serial port (luckily that still works, whew!). Anything I can try to figure out what's going on?
- Eli
Re: troubleshooting lan connection
Are you connecting to a LAN port on the router (and not a WAN port)?
Is your home network also on the 192.168.1.xxx subnet, and if so, have you taken measures to ensure that traffic to 192.168.1.1 actually gets to the router?
eli2k
Post by eli2k »
Yes, I have tried two different LAN ports. My home network is on 10.0.0.x subnet, and it's mostly wireless. In the computer network settings (XP), I set a random IP under 192.168.1.x w/gateway IP of 192.168.1.1, not sure if there was anything else I am supposed to change.
And I just noticed - why are you using a cross over cable? Try a normal ethernet cable instead.
eli2k
Post by eli2k »
Ah, good point. I will try a normal cable later tonight. I used a cross-over because in your tutorial you said "Save changes, restart the router, and connect an ethernet crossover cable (straight cable might work on some computers) to the router." I guess it makes sense to use a normal cable.
update - nah, that did not work either. I'm not familiar with linux. Is there a way to check the current network settings, kinda like the network info in Windows?
Hmm, good question! Does ifconfig work on the router? I don't have mine here to check.
Did you set a password when you were logged into the router on the serial console? If so, telnet won't work anymore. You would need to use ssh instead.
eli2k
Post by eli2k »
I don't think I set a password, because I can telnet normally over the wireless connection. The first code snippet is running ifconfig when the wireless is working normally:
root@OpenWrt:/# ifconfig
br-lan    Link encap:Ethernet  HWaddr XX:XX:XX:XX:XX:XX
          inet addr:10.0.0.4  Bcast:10.0.0.255  Mask:255.255.255.0
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:48 errors:0 dropped:0 overruns:0 frame:0
          TX packets:31 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:0
          RX bytes:4445 (4.3 KiB)  TX bytes:6211 (6.0 KiB)
eth0      Link encap:Ethernet  HWaddr XX:XX:XX:XX:XX:XX
          RX packets:0 errors:0 dropped:0 overruns:0 frame:0
          TX packets:51 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:0 (0.0 B)  TX bytes:16465 (16.0 KiB)
          Interrupt:4
eth0.0    Link encap:Ethernet  HWaddr XX:XX:XX:XX:XX:XX
          TX packets:21 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:0 (0.0 B)  TX bytes:4011 (3.9 KiB)
eth0.1    Link encap:Ethernet  HWaddr XX:XX:XX:XX:XX:XX
          TX packets:30 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:0 (0.0 B)  TX bytes:12180 (11.8 KiB)
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          UP LOOPBACK RUNNING  MTU:16436  Metric:1
          TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
wl0       Link encap:Ethernet  HWaddr XX:XX:XX:XX:XX:XX
          RX packets:48 errors:0 dropped:0 overruns:0 frame:5150
          TX packets:32 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:5117 (4.9 KiB)  TX bytes:6268 (6.1 KiB)
          Interrupt:2 Base address:0x5000
root@OpenWrt:/#
Connection to host lost.
This second snippet is after I changed the configuration settings in /etc/config/network file.
          TX packets:38 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:0 (0.0 B)  TX bytes:15580 (15.2 KiB)
          Interrupt:4
          inet addr:192.168.173.1  Bcast:192.168.173.255  Mask:255.255.255.0
          RX bytes:0 (0.0 B)  TX bytes:15428 (15.0 KiB)
          RX packets:23 errors:0 dropped:0 overruns:0 frame:6406
          TX packets:5 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:3833 (3.7 KiB)  TX bytes:1241 (1.2 KiB)
root@OpenWrt:/#
Very interesting. Can you post both copies of your /etc/config/network and /etc/config/wireless as well?
eli2k
Post by eli2k »
Here they are, below. have a Merry Christmas!
config wifi-device  wl0
        option type     broadcom
        option channel  2
        # option disabled 1
        option device   wl0
        option network  lan
        option mode     sta
        option ssid     MYSSID
        option encryption psk
        option key      MYKEY
/etc/config/network
#### VLAN configuration
config switch eth0
        option vlan0    "1 2 3 4 5*"
        option vlan1    "0 5"
#### Loopback configuration
config interface loopback
        option ifname   "lo"
        option proto    static
        option ipaddr   127.0.0.1
        option netmask  255.0.0.0
        option type     bridge
        option proto    dhcp
        # option proto  static
        # option ipaddr 192.168.173.1
        # option netmask        255.255.255.0
        # option gateway        192.168.173.1
        # option dns    192.168.173.1
#### WAN configuration
config interface        wan
        option ifname   "eth0.1"
        option proto    dhcp
A few things I see here:
In /etc/config/wireless:
The line that says "option type lan" should read "option type wan" instead.
/etc/config/network:
I recommend setting up the LAN like this:
	#option type 	bridge
	option proto	static
I also recommend making the firewall config changes listed in part 8 of the tutorial (http://mightyohm.com/blog/2009/05/build ... -and-ends/).
Try making those fixes and see if you can telnet to 192.168.1.1 from one of the LAN ports of the router, or over the wireless (note that you'll have to use the correct WAN IP for the router, this can usually be determined by looking at the status page of your home's wireless network.)
