[MPD]Adding stream URL to a Radiohacked Asus?
saschb2b
Post by saschb2b »
Hey community,
I was able to hack my Asus with the help of tinkernuts video
http://www.youtube.com/watch?v=Bp26xFBwrJs
And no I can start Ario player and select different Radio streams but
I can't add my own stations.. Like Technobase.fm or so.
The links have to look like this:
http://mp3.live.tv-radio.com/kissfm/all/kissfm-128k.mp3
http://mp3.live.tv-radio.com/francecult ... tdebit.mp3
http://broadcast.infomaniak.net/ouifm-high.mp3
These are some default streams but I want add streams that looks like this:
http://listen.technobase.fm/dsl.pls
Is there to convert the .pls to mp3 :) ?
Or maybe a other solution?
or generally how do I add music? Sry I'm a very beginner in building this radio.
Edit: Some links work and some not... So Techno4Ever works great! http://listen.to.techno4ever.net
but is there a wy to find play this playlist if the router starts up?
Re: [MPD]Adding stream URL to a Radiohacked Asus?
Sometimes if you open the pls files in notepad, you can get the actual stream URLs out of them. In this case I see
File1=http://listen.technobase.fm/tunein-dsl-pls
Title1=TechnoBase.FM - MP3 128k - High Quality - (DSL/Cable)
You might want to give that URL a try.
mtennant
Post by mtennant »
Winamp does a great job of decoding the underlying URL for streams.
Play the stream you want, then go to File | View File Info.
iTunes will do that too - great tip!
saschb2b
Post by saschb2b »
Wow I didn't know that thanks!
But for Technobase it didn't work.
I found this Website http://www.surfmusik.de/
If you open a stream and the right click on "Externer Player" and then copy link.
And then I can paste the copied IP-Adress to my MPD (Ario) Programm.
But now I'll use that "edit the .pls data" trick :) Thanks
