Looking for an alpha capable tube, I found an SBT-9 on eBay
I have two questions about wiring the SBT-9 to the Geiger kit.
- do you think it is safe to have both SBM-20 and SBT-9 connected in parallel at the same time, considering they operate at almost the same voltage (respectively 380 and 400v)? I'd rather avoid to connect/disconnect the SBM-20 too often by fear of breaking it and I don't want to permanently replace the SBM-20 as the SBT-9 seems to be less sensitive in the gamma-beta range. My plan is to add an easy connector (like header pins) to connect the SBT-9 to read alpha rays and disconnect it to read beta and gamma with the SBM-20.
- apparently the anode resitor for the SBT-9 is 10 MOhms. Can I simply put another 4,7 MOhm resistor in serial with the 4,7 MOhm resistor of the kit or is it better to have a single 10 MOhm resistor as close to the anode as possible? And what power should the resistance be able to withstand (e.g 1/4w, 1/2w, 1w...)?
As a bonus, here is a graph of some measurements made with the kit :
From 0 to 300 secondes the background radiation oscillates between 10 and 35 CPM, then a big granite cylinder puts the count between 25 and 50 CPM up to 850 seconds when I swhitch back to background and then again with the granite cylinder from 1100 to 1400 seconds.
Best regards,
Vincent Becker
