Failed.: Timeout occured
Reading :: TFTP Server.
TFTP_BLKLEN!!
break!! last block!!
Done. 1230520 bytes read
Download of 0x12c6b8 bytes completed
Write kernel and filesystem binary to FLASH (0xbfc20000)
Programming...
copysize=1230520, amtcopy=1230520
done. 1230520 bytes written
Decompressing..........done
CFE version 1.0.37 for BCM947XX (32bit,SP,LE)
Build Date: Thu Mar 6 10:05:04 CST 2008 (root@localhost.localdomain)
Copyright (C) 2000,2001,2002,2003 Broadcom Corporation.
Initializing Arena
Initializing Devices.
Boot partition size = 131072(0x20000)
et0: Broadcom BCM47xx 10/100 Mbps Ethernet Controller 4.130.31.0
CPU type 0x29029: 240MHz
Total memory: 16384 KBytes
Total memory used by CFE: 0x80400000 - 0x80497FF0 (622576)
Initialized Data: 0x8042F370 - 0x80431830 (9408)
BSS Area: 0x80431830 - 0x80431FF0 (1984)
Local Heap: 0x80431FF0 - 0x80495FF0 (409600)
Stack Area: 0x80495FF0 - 0x80497FF0 (8192)
Text (code) segment: 0x80400000 - 0x8042F370 (193392)
Boot area (physical): 0x00498000 - 0x004D8000
Relocation Factor: I:00000000 - D:00000000
Device eth0: hwaddr E0-CB-4E-9A-7F-EA, ipaddr 192.168.1.1, mask 255.255.255.0
gateway not set, nameserver not set
Null Rescue Flag.
Boot program checksum is invalid
Hello!! Enter Rescue Mode: (Check error)
