very slow mpd
bola
very slow mpd
Post by bola »
Hi.
Is there any solution to fix the speed problem with mpd?
if i send the volume command it takes about 5s until mpd will set it up.
thats very annoying while using it as a webradio.
Re: very slow mpd
I think I've seen this too. You could try reducing the audio buffer size in /etc/mpd.conf, but you may experience skips in playback as a result.
########################### BUFFERING ##########################
# The size of the buffer containing decoded audio.  You probably
# shouldn't change this.
#audio_buffer_size               "2048"
# How much of the buffer to fill before beginning to play.
# Increase this if you hear skipping when changing songs.
#buffer_before_play              "10%"
# Similar options for the HTTP stream buffer.  If you hear
# skipping while playing HTTP streams, you may wish to increase
# these.
#http_buffer_size                "128"
#http_prebuffer_size             "25%"
bola
Re: very slow mpd
Post by bola »
hm no change. it still takes a lot of time until mpd will set the volume. other actions like play, stop are much faster.
is there no other way to set the volume of oss ? maybe /dev/sound/mixer but i cant find a way to communicate
