Welcome tinkernuts
Welcome tinkernuts
Hello!
If you are here because you saw Tinkernut's "How to Make a Cheap Wifi Radio" video (http://www.tinkernut.com/?p=2387) then welcome!
Please keep in mind that the people on this forum (at mightyohm.com) most likely had nothing to do with tinkernut's tutorial, and may not be able to help you with problems you encounter while following it. If you get stuck and need help with Tinkernut's tutorial, the best way to get support is to contact him or post about your issue on the Tinkernut forums.
Contact: http://tinkernut.com/requests-2
Forum: http://tinkernut.com/forum
That said, Tinkernut's tutorial is based on a tutorial I wrote on this site in late 2008/early 2009 (and uses the same firmware on the router) :
http://mightyohm.com/blog/2008/10/build ... roduction/
So if your issue is related to the firmware or a general WL-520gU issue, we might be able to help you if you ask nicely. :D
n0ukf
Re: Welcome tinkernuts
Post by n0ukf »
mightyohm wrote:If you are here because you saw Tinkernut's "How to Make a Cheap Wifi Radio" video (http://tinkernut.com/archives/2387) then welcome!
That link is no longer valid, he must be reorganizing the site. On the homepage (http://tinkernut.com/) I followed the DIY Projects link to find the WiFi Radio video.
