No internet connection
Muffinman
Post by Muffinman »
Hi Guys,
I'm from Germany and new in this forum. I love the Wifi Radio Project and i would like to create my own radio. I bought the asus wl520gu and i tried to flash and config openwrt on the router. I tried the tutorial from tinkernut (http://www.youtube.com/watch?v=Bp26xFBw ... r_embedded), but it won't work. I get no internet connection when i try to update opkg.
config wifi-device  wl0
        option type     broadcom
        option channel  9
        option device   wl0
        option network  wlan
        option mode     sta
        option ssid     MySSID
        option encryption psk2
        option key      MyKey
        option vlan0    "1 2 3 4 5*"
        option vlan1    "0 5"
        option ifname   "lo"
        option proto    static
        option ipaddr   127.0.0.1
        option netmask  255.0.0.0
        option type     bridge
        option ifname   "eth0.0"
        option proto    static
        option ipaddr   192.168.1.10
        option netmask  255.255.255.0
        option gateway  192.168.1.2
        option dns      8.8.8.8
root@OpenWrt:~# opkg update
Downloading http://mightyohm.com/files/kamikaze-2.4/packages/mipsel/Packages.gz
wget: bad address 'mightyohm.com'
Signiture check for snapshots skipped because GPG support was not enabled in this build
Collected errors:
 * opkg_download: ERROR: Command failed with return value 1: `wget --passive-ftp    -P /tmp/opkg-JPeQJf http://mightyohm.com/files/kamikaze-2.4/packages/mipsel/Packages.gz'
Can you help me?
Greets John
Re: No internet connection
Post by jeroen94704 »
In the wifi config file, you need to change the "MySSID" and "MyKey" (and maybe the "encryption") settings to match your local network setup.
Muffinman
Post by Muffinman »
Yes i know....i removed them for this post.
The SSID is WLan - Hauss , the Key is supermann and The encryption is WPA2 CCMP.
Whoops, sorry, I jumped to conclusions :)
Looking further, you place the wl0 device in the "wlan" network, but there is no definition for "wlan" in /etc/config/network. You need to add something about wlan there, such as (in my case):
config 'interface' 'wlan'
        option 'proto' 'dhcp'
        option 'type' 'bridge'
        option 'ifname' 'wl0'
        option 'defaultroute' '0'
        option 'peerdns' '0'
Muffinman
Post by Muffinman »
Okay i edited the vi /etc/config/network, but i get no connection.
root@OpenWrt:~# vi /etc/config/network
        option vlan1    "0 5"
        option ifname   "lo"
        option proto    static
        option type bridge
        option proto    static
        option dns      8.8.8.8
config interface        wan
        option ifname   "eth0.1"
        option proto    dhcp
#### WLAN configuration
config interface wlan
        option proto    dhcp
        option type     bridge
        option ifname   wl0
        option defaultroute 0
        option peerdns  0
root@OpenWrt:~# vi /etc/config/wireless
        option channel  9
        option device   wl0
        option network  wlan
        option mode     sta
        option ssid     WLan - Hauss
        option key      supermann
Your /etc/config/wireless looks ok, although you could try wrapping your SSID in single quotes.
Here's my complete /etc/config/network, which helped someone else on this forum before:
config 'switch' 'eth0'
config 'interface' 'loopback'
        option 'ifname' 'lo'
        option 'proto' 'static'
        option 'ipaddr' '127.0.0.1'
        option 'netmask' '255.0.0.0'
config 'interface' 'lan'
        option 'ifname' 'eth0.0'
config 'interface' 'wan'
        option 'ifname' 'eth0.1'
config 'switch_vlan' 'eth0_0'
        option 'device' 'eth0'
        option 'vlan' '0'
        option 'ports' '1 2 3 4 5'
config 'switch_vlan' 'eth0_1'
        option 'vlan' '1'
        option 'ports' '0 5'
Muffinman
Post by Muffinman »
Thanks, do you use the router as the Wifi Radio from Jeff or as the Radio from tinkernut?
Neither. I simply installed the Backfire release of OpenWrt and configured the whole thing myself. But I do use it in the same way as a music player which plays music from the local network or from an internet stream.
Muffinman
Post by Muffinman »
Okay. I used the openwrt-brcm-2.4-squashf.trx from http://mightyohm.com/files/kamikaze-2.4 ... uashfs.trx
I can't find the problem. Maybe my repeater is a problem or should i connect the wl520gu directly to my router?
WPA2-CCMP might be the problem. Can you change your wireless network to WPA2-AES instead?
I have had problems getting OpenWRT to connect to certain WPA/WPA2 configurations. WEP pretty much always works. I use WPA2-AES here and it seems to work ok, but I had to put single quotes around my network key because it has some special (non-alphanumeric) characters in it.
And I think you need to enclose your SSID in single quotes ie. 'My SSID has spaces' or change your SSID to something easier (no spaces or special characters).
