Reinstall OpenWrt on WL-520gU
procrastineer
Post by procrastineer »
Hi guys.
I successfully installed OpenWrt on my router as per instructions on the blog. I installed different packages using opkg and decided to reinstall OpenWrt.
However I'm having trouble transferring the .trx file on to the router. I'm using a macbook pro with airport disabled since my home network is also in the 192.168.1.x range. I'm also using the USB-serial FTDI cable withZTerm. The lan cable is connected to the LAN1 and macbook pro. I get following output on the Terminal:
tftp> trace
Packet tracing off.
tftp> trace
Packet tracing on.
tftp> timeout 1
tftp> mode binary
tftp> connect 192.168.1.1
tftp> put openwrt-brcm-2.4-squashfs.trx
sent WRQ <file=openwrt-brcm-2.4-squashfs.trx, mode=octet>
Transfer timed out.
From the output of the ZTerm my macbook can talk to the router; I get the following output on ZTerm when sending the file:
Reading :: TFTP Server.
Failed.: Timeout occured
BUF == NULL!!
BUF == NULL!!
BUF == NULL!!
break!! by max retry!!
I'm little confused by the output on Terminal "sent WRQ <file=openwrt-brcm-2.4-squashfs.trx, mode=octet>". I thought transfer mode will be binary rather than octet. Can someone help. Thanks.
Re: Reinstall OpenWrt on WL-520gU
Did you figure this out?
I don't see anything immediately wrong with what you are doing. Is the file openwrt-brcm-2.4-squashfs.trx in the directory where you are running tftp?
zordlyon
Post by zordlyon »
I'm getting the same problem, and yes i have tftp on the directory of the brcm47xx...
I have used the restoration tool to recover the original firmware to try reinstall another openwrt and i got the same error...
If anyone can help, i appreciate,
Thanks..
Post by gerben »
You could try it again using windows and see if you get the same error.
