OPKG url invailed
Posted: Mon Nov 14, 2011 4:44 am
each time i type opkg update i get the following error:
what does it means ,that it needs a passive ftp connection or ..?
the config:
root@OpenWrt:/# opkg update
Downloading http://mightyohm.com/files/kamikaze-2.4/packages/mipsel/Packages/Pac
kages.gz
wget: bad address 'mightyohm.com'
Signiture check for snapshots skipped because GPG support was not enabled in thi
s build
Collected errors:
* opkg_download: ERROR: Command failed with return value 1: `wget --passive-ftp
-P /tmp/opkg-fVoDTC http://mightyohm.com/files/kamikaze-2.4/packages/mipsel/
Packages/Packages.gz'
root@OpenWrt:/#
the config:
src/gz snapshots http://mightyohm.com/files/kamikaze-2.4/packages/mipsel/Packages/mipsel
dest root /
dest ram /tmp
lists_dir ext /var/opkg-lists
