Is there a limit to the number of stations?
jasonkunc
Post by jasonkunc »
First off I'd like to say thank you to all for everybody's hard work on this project.
I've had everything working just fine for some time now. A few stations that I listen to changed there feed URL, so I had to change my interface.sh file. My question is there a limit of stations that I can have? I can SSH into the router to change the stations fine, but changing the station with the physical pot seems to stop. It will not go all the way to the end of the playlist. I don't know if it is a hardware problem or software. I'm using a 10K pot, should I change it?
Re: Is there a limit to the number of stations?
Make sure the STATIONS variable at the top of interface.sh agrees with the # of stations in your list.
You can add as many stations as you want, there is a limit but it is probably above 50-100 stations at least.
jasonkunc
Post by jasonkunc »
Thanks, that was it. STATIONS was set to 11 and I had 15 stations that I wanted to listen too.
good stuff
thanks
