how to make a proxy configuration?
Posted: Sun Dec 12, 2010 11:31 pm
by nexux
Hello, my name is Andrei and I'm from Russia, then sorry for my bad english)
I have already setup asus like you say on youtube. point to point - now its working perfect thru my AP at home.
but now i want to move it another place, where stream has a proxy connection.
What should I do to configurate it?
Re: how to make a proxy configuration?
Posted: Sun Dec 12, 2010 11:50 pm
by jeroen94704
Apparently there is a set of proxy settings you can add to your mpd.conf file (although I have never tried these myself):
http_proxy_host <hostname>
    Use to specify the proxy host used for HTTP connections.
http_proxy_port <port>
    The port that the HTTP proxy host uses.
http_proxy_user <username>
    If the HTTP proxy server requires authentication, this specifies the username.
http_proxy_password <password>
    If the HTTP proxy server requires authentication, this specifies the password.
Hope this helps,
Posted: Mon Dec 13, 2010 2:40 am
by nexux
thx!
can I use domain name here?
for example "
http_proxy_user ORG\W.Smith
Posted: Mon Dec 20, 2010 10:53 am
If your proxy does not require authentication, try leaving those settings out. If your proxy does require a username and password, then you would enter them for the <username> and <password>.
I have never tried to use a proxy with mpd, so I have no idea if it works (or the version running on the router even supports it).
