Need help!
arthrod
Need help!
Post by arthrod »
Guys,
I tried to update my asus. Everything worked until I had to OPKG update.
Take a look on the screen:
http://i54.tinypic.com/htu4n4.jpg
plz help :P
Re: Need help!
Post by jeroen94704 »
It looks like the router does not have an internet connection at all. Can you wget from other sites? Try
wget http://www.cnn.com
and see what happens. If that returns the same error, that means the router simply has no connection to the internet, which could be caused by a number of things. Given that you are apparently able to access the router through the local network, I'd be interested to see your network config.
