Looking for Larger Alphanumeric Display
Posted: Wed Jun 30, 2010 11:44 pm
I would like to build a version of the MightyOhm radio in a larger box to match the style of the typical AM/FM receiver. I really want an alphanumeric display that is large enough to read from across the room, since most of the internet radio stations I listen to do not announce the track that is being played.
Most of the LCD displays I find in the catalogs have characters that are about 1/4 inch high. Displays larger than that (that would be practical for this purpose) seem to be more expensive than the combined cost of the rest of the project.
I would be happy with a single-line LCD display and a minimum of around 25 or 30 characters. It will help a lot if it can scroll horizontally pixel-by-pixel instead of a character at a time.
I was considering other options if I cannot get the larger LCD display I want:
An LCD photo frame would be ideal, but I haven't seen them mentioned on this message board recently. I assume that connecting the photo frame interface to the WL-523gU is a tough problem or someone would have done it already.
Another possibility would be to use the LCD display from a consumer product such as an old camcorder. Presumably that would require an ASCII-to-video converter. IC's for that purpose should be readily available. Could someone suggest where I might find information on ASCII-to-video circuits?
I also wonder if it would be practical to use a small LCD display from an old laptop computer. If the LCD's have something resembling a VGA interface, then an ASCII-to-VGA converter could probably be used.
Thanks for any suggestions,
Lloyd
Lloyd
