Who was looking for boot from USB?
regiscruzbr
Post by regiscruzbr »
I was looking for detailed instructions about how install mpd 1.5.2 on my router when I found this.
https://forum.openwrt.org/viewtopic.php?id=21377
I didn't try, but looks simple, especially the suggestion from Mr. Mavy.
Who want try? ;)
pxshock
Re: Who was looking for boot from USB?
Post by pxshock »
Has any one got this to work? I just spent the last 10 hrs trying, and i dont know what i am doing wrong.
i tried a number of resources, but no go on booting from usb flash disk . :-(
https://forum.openwrt.org/viewtopic.php?id=11495
https://forum.openwrt.org/viewtopic.php?id=17642
http://wiki.openwrt.org/oldwiki/usbstoragehowto
http://wiki.openwrt.org/oldwiki/openwrt ... diahowto?s
http://wiki.openwrt.org/oldwiki/nielsbo ... .partition
lots of reading, lots of copy and pasting, loaaads of rebooting.
Please let us know if any one has gotten this to work
Since were more discussing about the wl-520gU. it might be beneficial to the wifi project.
eli2k
Post by eli2k »
nifty! this means you can run unlimited things on the router this way?
ilinux
Post by ilinux »
.your problem is that your router can't support glib because is too huge.
You can install 0.13.x version or maybe you can install mpd on usb..
In my opinion if you don't need last.fm I suggest to use 0.13 version because the last from trunk don't allow to play mms stream and aac :roll:
If you can wait some days I suggest to install wrtradio 0.2 (not wrtradio 0.1 because is over your flash size) with comes with all needs .
Let me know :D
pxshock
Post by pxshock »
ilinux wrote:.your problem is that your router can't support glib because is too huge.
Let me know :D
I would like to make my router an all purpose device, and i am running out of space to install apps, wifi radio among other things, that is why i wanted to boot from usb.
I took the day off today, you know to clear my head, ill be at it tomorrow. Ill certainly post my results. And, again, if any one has had any success with booting from usb, please let us know.
pxshock
Post by pxshock »
got it to work finally!!!
Try to read, and understand, and follow with precision.
this is another good link i used
http://www.yorkspace.com/2009/03/134
my issue was the modules, i wasnt calling the right ones...seems i was missing out the usb 2 module "insmod ehci-hcd" because my hub apparently needed it (i wasted sooo much time on this!)
The awesome thing is that, if you pluck out the usb, then it just boots from the routers flash. :-)
You can now boot from usb flash drive with OpenWRT on the asus WL-520gU
here is my pivotroot file
vi /etc/init.d/pivotroot
#!/bin/sh
# change this to your boot partition
boot_dev="/dev/scsi/host0/bus0/target0/lun0/part1"
# install needed modules for usb and the ext3 filesystem
# **NOTE** for usb2.0 replace "uhci" with "ehci_hcd"
# **NOTE** for ohci chipsets replace "uhci" with "usb-ohci"
for module in usbcore ehci-hcd usb-ohci scsi_mod sd_mod usb-storage jbd ext2 ext3 ; do {
insmod $module
}; done
# this may need to be higher if your disk is slow to initialize
sleep 12s
# mount the usb stick
mount "$boot_dev" /mnt
# if everything looks ok, do the pivot root
[ -x /mnt/sbin/init ] && {
mount -o move /proc /mnt/proc && \
pivot_root /mnt /mnt/mnt && {
mount -o move /mnt/dev /dev
mount -o move /mnt/tmp /tmp
mount -o move /mnt/jffs2 /jffs2 2>&-
mount -o move /mnt/sys /sys 2>&-
here is my rcS file
vi /etc/init.d/rcS
#!/bin/sh
# Copyright (C) 2006 OpenWrt.org
if test $2 == "boot" ; then
fi
for i in /etc/rc.d/$1*; do
$i $2 2>&1
done
} | logger -s -p 6 -t '' &
vi /etc/modules.d/60-usb-storage
scsi_mod max_scsi_luns=8
sd_mod
usb-storage
_------------_____________------------------_______________-----------------__________----------------_________-----------------____-----
here is some proof :-)
BusyBox v1.11.2 (2009-12-02 06:19:32 UTC) built-in shell (ash)
Enter 'help' for a list of built-in commands.
_______ ________ __
| |.-----.-----.-----.| | | |.----.| |_
| - || _ | -__| || | | || _|| _|
|_______|| __|_____|__|__||________||__| |____|
|__| W I R E L E S S F R E E D O M
KAMIKAZE (8.09.2, r18961) -------------------------
* 10 oz Vodka Shake well with ice and strain
* 10 oz Triple sec mixture into 10 shot glasses.
* 10 oz lime juice Salute!
root@OpenWrt:~# df -h
Filesystem Size Used Available Use% Mounted on
rootfs 949.6M 25.0M 876.4M 3% /
/dev/root 1.6M 1.6M 0 100% /mnt/rom
tmpfs 7.0M 48.0k 6.9M 1% /tmp
/dev/mtdblock/4 1.8M 1.1M 756.0k 59% /mnt/jffs
mini_fo:/jffs 1.6M 1.6M 0 100% /mnt
root@OpenWrt:~# opkg update
Downloading http://downloads.openwrt.org/kamikaze/8 ... ackages.gz
Connecting to downloads.openwrt.org (78.24.191.177:80)
Packages.gz 100% |************************************************************************************************************| 130k 00:00:00 ETA
Inflating http://downloads.openwrt.org/kamikaze/8 ... ackages.gz
Updated list of available packages in /var/opkg-lists/snapshots
root@OpenWrt:~# opkg install nano
Installing nano (2.0.7-1) to root...
Downloading http://downloads.openwrt.org/kamikaze/8 ... mipsel.ipk
nano_2.0.7-1_mipsel. 100% |************************************************************************************************************| 32604 00:00:00 ETA
Installing libncurses (5.6-1) to root...
libncurses_5.6-1_mip 100% |************************************************************************************************************| 139k 00:00:00 ETA
Configuring libncurses
Configuring nano
rootfs 949.6M 25.5M 875.9M 3% /
tmpfs 7.0M 700.0k 6.3M 10% /tmp
root@OpenWrt:~# opkg install rtorrent
Installing rtorrent (0.8.2-1.1) to root...
rtorrent_0.8.2-1.1_m 100% |************************************************************************************************************| 448k 00:00:00 ETA
Installing libcurl (7.17.1-1.2) to root...
libcurl_7.17.1-1.2_m 100% |************************************************************************************************************| 96349 00:00:00 ETA
Installing libopenssl (0.9.8i-3.2) to root...
libopenssl_0.9.8i-3. 100% |************************************************************************************************************| 472k 00:00:00 ETA
Installing zlib (1.2.3-5) to root...
zlib_1.2.3-5_mipsel. 100% |************************************************************************************************************| 35671 --:--:-- ETA
Installing libtorrent (0.12.4-1.1) to root...
libtorrent_0.12.4-1. 100% |************************************************************************************************************| 459k 00:00:00 ETA 459k 00:00:00 ETA
Installing libsigcxx (2.2.3-1.1) to root...
wget: no response from server
Configuring libcurl
Configuring libopenssl
Configuring libtorrent
Configuring zlib
Collected errors:
* opkg_download: ERROR: Command failed with return value 1: `wget --passive-ftp -P /tmp/opkg-YruoGL http://downloads.openwrt.org/kamikaze/8 ... mipsel.ipk'
* Failed to download libsigcxx. Perhaps you need to run 'opkg update'?
libsigcxx_2.2.3-1.1_ 100% |************************************************************************************************************| 10235 --:--:-- ETA
Installing libstdcpp (3.4.6-14.3) to root...
libstdcpp_3.4.6-14.3 100% |************************************************************************************************************| 148k 00:00:00 ETA
Configuring libsigcxx
Configuring libstdcpp
Configuring rtorrent
root@OpenWrt:~# opkg install screen
Installing screen (4.0.3-1) to root...
screen_4.0.3-1_mipse 100% |************************************************************************************************************| 158k 00:00:00 ETA
Configuring screen
rootfs 949.6M 31.6M 869.7M 4% /
root@OpenWrt:~#
pxshock,
Very nice work! This should be very helpful for others trying to get more out of their 520gU than the builtin flash allows.
Now I have another thing I need to play with when I pick up my next router. :D
Thanks for posting!
Post by jeroen94704 »
Just to add a bit to this: I tried getting my WL-500G to boot from USB as well, but it's just too complicated for my taste. So instead, I install the necessary USB-storage packages and install packages that don't fit on the router's own flash memory on a USB memory stick. The gotcha here is that you need to set the LD_LIBRARY_PATH environment variable, or applications won't be able to find the libraries you install on the USB target.
