where to get config and source
mcfloppy
Post by mcfloppy »
i want a System, which can play networkstreams and music from local source over cifs protocol. The original MightyOhm-Firmware has no support for CIFS, so i build my own firmware. First i tried with the backfire release, but the image was to big. So i used the 8.09 kamikaze Version. With the 8.09 i have serveral problems, so i cant control the volume (!= 100% is stucking) and i cant add webradios. After some readings about the mpd uri problem, i know now i need a older mpd-version. After 16 build firmwares i'll ask for the original source and config, to compile CIFS support :)
Can you upload working source/config?
Greetings McFloppy
Re: where to get config and source
I will look but I don't think I have a copy of the source I used to compile the firmware used in the tutorial. I got rid of the PC I was using at the time and I don't know if I backed up everything as the source was quite large.
