mpc playing but no output ?
Im using Tp-link TL-MR3220 , hacked ( openwrt )
i done everything step by step , until i reached the finals step :
when i write : Mpd
it loads successfully , and when i run mpc
i get volume 100% .....
so i add a radio server http://relay3......
then when i hit , mpc play i get :
http://relay3......
playing #1/1 0:00/0:00 (0%)
volume 100% repeat .....
but i dont hear anything ?
when i write : Mpd
http://relay3......
Re: mpc playing but no output ?
Which soundcard do you use?
I had no luck with that one, but no problems with the device that shows up when you search ebay for "USB Sound Card 7.1 Channel 3D Audio"7amadabsi wrote: this one : http://www.uxcell.com/usb-sound-audio-s ... -2712.html
See this post! http://www.mightyohm.com/forum/viewtopic.php?f=2&t=232
Ok, guys. I've managed to install and run mpd on my flash drive. I run it with following audio_output settings in mpd.conf
it runs without a word, everything looks fine. I start Ario on my PC and push the play button. I see timer running in Ario and AIR led blinking on router. Led on the USB sound card doesn't blink as it should when working. And I can hear no sound.
I run mpc on router - and it gives me:
I try mpc volume +10 and it gives me:
I'm using Asus WL-520GU (Backfire OpenWRT 10.03 brcm2.4), A4Tech USB Hub and plugged in it USB sound card (right this one: http://www.ebay.com/itm/New-USB-2-0-to- ... 4ab86672b4).
I've tried to comment following lines in mpd.conf
but no luck
related dmesg part:
opkg list-installed
I'm feeling I'm right near success and would appreciate your help.
audio_output {
type "oss"
name "My OSS Device"
device "/dev/sound/dsp" # optional
format "44100:16:2" # optional
mixer_device "/dev/sound/mixer" # optional
mixer_control "PCM" # optional
root@OpenWrt:/mnt/usb/.mpd# mpc
volume: n/a repeat: off random: off single: off consume: off
root@OpenWrt:/mnt/usb/.mpd# mpc volume +10
error: ACK [52@0] {volume} problems setting volume
# mixer_device "/dev/sound/mixer" # optional
# mixer_control "PCM" # optional
related dmesg part:
USB20H fcr: 0x64
USB20H shim cr: 0x8f7
PCI: Setting latency timer of device 00:03.1 to 64
ehci_hcd 00:03.1: PCI device 14e4:471a
ehci_hcd 00:03.1: irq 6, pci mem b8003800
ehci_hcd 00:03.1: illegal capability!
ehci_hcd 00:03.1: USB 0.0 enabled, EHCI 1.00, driver 2003-Dec-29/2.4
hub.c: USB hub found
hub.c: 2 ports detected
ip_conntrack version 2.1 (5953 buckets, 5953 max) - 352 bytes per conntrack
hub.c: new USB device 00:03.1-1, assigned address 2
hub.c: 4 ports detected
SB USB20H init
SB COREREV: 2
USB20H fcr: 0x64
PCI: Setting latency timer of device 00:03.0 to 64
usb.c: new USB bus registered, assigned bus number 2
uhci.c: USB Universal Host Controller Interface driver v1.1
hub.c: new USB device 00:03.1-1.1, assigned address 3
usb.c: USB device not accepting new address=3 (error=-32)
hub.c: new USB device 00:03.1-1.1, assigned address 4
usbaudio: device 4 audiocontrol interface 0 has 1 input and 1 output AudioStreaming interfaces
usbaudio: device 4 interface 2 altsetting 1 channels 1 framesize 2 configured
usbaudio: valid input sample rate 48000
usbaudio: valid input sample rate 44100
usbaudio: device 4 interface 2 altsetting 1: format 0x00000010 sratelo 44100 sratehi 48000 attributes 0x01
usbaudio: device 4 interface 1 altsetting 0 does not have an endpoint
usbaudio: device 4 interface 1 altsetting 1 channels 2 framesize 2 configured
usbaudio: valid output sample rate 48000
usbaudio: valid output sample rate 44100
usbaudio: device 4 interface 1 altsetting 1: format 0x01000010 sratelo 44100 sratehi 48000 attributes 0x01
usbaudio: registered dsp 14,3
usbaudio: constructing mixer for Terminal 6 type 0x0301
Initializing USB Mass Storage driver...
usb.c: registered new driver usb-storage
USB Mass Storage support registered.
usbaudio: warning: found 1 of 2 logical channels.
usbaudio: assuming that a stereo channel connected directly to a mixer is missing in search (got Labtec headset?). Should be fine.
usbaudio: constructing mixer for Terminal 7 type 0x0101
usb_audio_parsecontrol: usb_audio_state at 80a3c7a0
hub.c: new USB device 00:03.1-1.4, assigned address 5
scsi0 : SCSI emulation for USB Mass Storage devices
Vendor: JetFlash Model: TS1GJFV30 Rev: 8.07
Type: Direct-Access ANSI SCSI revision: 02
Attached scsi removable disk sda at scsi0, channel 0, id 0, lun 0
SCSI device sda: 1986560 512-byte hdwr sectors (1017 MB)
sda: Write Protect is off
Partition check:
/dev/scsi/host0/bus0/target0/lun0: p1
WARNING: USB Mass Storage data integrity not assured
USB Mass Storage device found at 5
opkg list-installed
root@OpenWrt:/etc/modules.d# opkg list-installed
alsa-lib - 1.0.21a-1
base-files - 42-r20728
block-mount - 0.1.0-1
busybox - 1.15.3-2
dnsmasq - 2.52-2
dropbear - 0.52-4
fdisk - 2.13.0.1-4
firewall - 1-10
glib2 - 2.22.2-1
iptables - 1.4.6-2
iptables-mod-conntrack - 1.4.6-2
iptables-mod-nat - 1.4.6-2
kernel - 2.4.37.9-1
kmod-brcm-wl - 2.4.37.9+4.150.10.5.3-6
kmod-diag - 2.4.37.9-6
kmod-fs-ext2 - 2.4.37.9-1
kmod-fs-ext3 - 2.4.37.9-1
kmod-fs-vfat - 2.4.37.9-1
kmod-ipt-conntrack - 2.4.37.9-1
kmod-ipt-core - 2.4.37.9-1
kmod-ipt-nat - 2.4.37.9-1
kmod-ipt-nathelper - 2.4.37.9-1
kmod-ppp - 2.4.37.9-1
kmod-pppoe - 2.4.37.9-1
kmod-scsi-core - 2.4.37.9-1
kmod-sound-core - 2.4.37.9-1
kmod-switch - 2.4.37.9-3
kmod-usb-audio - 2.4.37.9-1
kmod-usb-core - 2.4.37.9-1
kmod-usb-ohci - 2.4.37.9-1
kmod-usb-storage - 2.4.37.9-1
kmod-usb-uhci - 2.4.37.9-1
kmod-usb2 - 2.4.37.9-1
kmod-wlcompat - 2.4.37.9+4.150.10.5.3-6
ldconfig - 0.9.30.1-42
libc - 0.9.30.1-42
libcurl - 7.19.6-1
libfaad2 - 2.7-1
libffmpeg - 20080419-2
libflac - 1.1.2-1
libgcc - 3.4.6-42
libiconv - 1.11-1
libid3tag - 0.15.1b-3
libintl - 0.17-1
libiptc - 1.4.6-2
liblua - 5.1.4-6
libmad - 0.15.1b-3
libmms - 0.5-1
libogg - 1.1.4-2
libopenssl - 0.9.8m-3
libpthread - 0.9.30.1-42
librt - 0.9.30.1-42
libshout - 2.2.2-1
libspeex - 1.2beta3.2-2
libsqlite3 - 3.6.20-2
libuci - 12012009.5-1
libuci-lua - 12012009.5-1
libvorbis - 1.2.3-1
libvorbisidec - 1.0.2+svn14261-1
libxtables - 1.4.6-2
lua - 5.1.4-6
luci - 0.9.0-1
luci-admin-core - 0.9.0-1
luci-admin-full - 0.9.0-1
luci-admin-mini - 0.9.0-1
luci-app-firewall - 0.9.0-1
luci-app-initmgr - 0.9.0-1
luci-cbi - 0.9.0-1
luci-core - 0.9.0-1
luci-http - 0.9.0-1
luci-i18n-english - 0.9.0-1
luci-ipkg - 0.9.0-1
luci-lmo - 0.9.0-1
luci-nixio - 0.9.0-1
luci-sgi-cgi - 0.9.0-1
luci-sys - 0.9.0-1
luci-theme-base - 0.9.0-1
luci-theme-openwrt - 0.9.0-1
luci-uci - 0.9.0-1
luci-uvl - 0.9.0-1
luci-web - 0.9.0-1
mdnsresponder - 107.6-1
mpc - 0.17-1
mpd - 0.15.8-2
mtd - 12
nas - 4.150.10.5.3-6
nvram - 5
opkg - 513-2
ppp - 2.4.4-5
ppp-mod-pppoe - 2.4.4-5
uci - 12012009.5-1
uhttpd - 7
wireless-tools - 29-4
wlc - 4.150.10.5.3-6
zlib - 1.2.3-5
Is MPD is running in the background? should give a list of all processes.
ps -aux
Here's my command sequence with ps -aux output:
root@OpenWrt:~# mpd /mnt/usb/etc/mpd.conf
root@OpenWrt:~# mpc playlist
>1) gilmourish.com - high_hopes_backingtrack
[playing] #1/1 0:00/7:50 (0%)
root@OpenWrt:~# ps -aux
PID USER VSZ STAT COMMAND
1 root 1408 S init
2 root 0 SW [keventd]
3 root 0 SWN [ksoftirqd_CPU0]
4 root 0 SW [kswapd]
5 root 0 SW [bdflush]
6 root 0 SW [kupdated]
8 root 0 SW [mtdblockd]
101 root 0 SWN [jffs2_gcd_mtd4]
125 root 1408 S init
151 root 1420 S syslogd -C16
153 root 1400 S klogd
274 root 0 SW [khubd]
304 root 1408 S udhcpc -t 0 -i eth0.1 -b -p /var/run/eth0.1.pid -O ro
517 root 0 SW [usb-storage-0]
520 root 0 SW [scsi_eh_0]
688 root 1120 S /usr/sbin/dropbear -p 22 -P /var/run/dropbear.1.pid
694 root 1408 S /usr/sbin/uhttpd -f -h /www -r OpenWrt -x /cgi-bin -t
709 nobody 860 S /usr/sbin/dnsmasq -K -D -y -Z -b -E -s lan -S /lan/ -
717 root 1180 S /usr/sbin/dropbear -p 22 -P /var/run/dropbear.1.pid
718 root 1412 S -ash
725 root 0 SW [kjournald]
735 root 13540 S mpd /mnt/usb/etc/mpd.conf
736 root 13540 S mpd /mnt/usb/etc/mpd.conf
737 root 13540 S mpd /mnt/usb/etc/mpd.conf
738 root 13540 S mpd /mnt/usb/etc/mpd.conf
741 root 13540 S mpd /mnt/usb/etc/mpd.conf
742 root 1404 R ps -aux
Well, after several attempts to run mpc via OSS and ALSA in various freaking ways I've reinstalled OpenWRT from MightyOhm precompiled image. Surprisingly it installed successfully, so gerben was right - some error during download or I don't know..
And it works! Thanks to MightyOhm for great tutorial!
As conclusion - either Backfire 10.03, nor Backfire 10.03.1 (a bit slower than 10.03) won't work with described setup. At least that didn't work for me.
