high voltage not working
Posted: Mon Feb 08, 2016 7:56 am
Hi all,
I etched the board and assembled it with the correct parts. I programmed the AVR. When I short GND with TP1 I get a beep and a flashing LED. I don't get any HV, shorting the pins of the geiger tube does nothing. I checked and my 555 timer still works. I need some help to figure out what's wrong. I've never been very good with bipolar transistors, and I don't mange to figure out how the HV part works. I've spent quite a bit of time on this forum to figure out things.
I tried the circuit with other transistors for Q1, since the FJN3303F isnt tooe asy to get, this didn't work. I specially ordered FJN3303F's at another supplier, soldering in one of these didn't help.
When I remove U1 and short U1 socket pins 3 and 8 together, I measure the battery voltage on pin4.
When I remove U1 (555 timer) I get these voltages:
1 0v
2 0v
3 -0.059v
4 3.164v
5 0v
6 0v
7 -0.38v
8 3.192v
When I insert U1:
1 0v
2 1.423v
3 1.808v
4 3.157v
5 2.119v
6 0v
7 0.749v
8 3.181v
1 0v
2 0v
3 -0.059v
4 3.164v
5 0v
6 0v
7 -0.38v
8 3.192v
When I insert U1:
1 0v
2 1.423v
3 1.808v
4 3.157v
5 2.119v
6 0v
7 0.749v
8 3.181v
