I'm from Germany and new in this forum. I love the Wifi Radio Project and i would like to create my own radio. I bought the asus wl520gu and i tried to flash and config openwrt on the router. I tried the tutorial from tinkernut (http://www.youtube.com/watch?v=Bp26xFBw ... r_embedded), but it won't work. I get no internet connection when i try to update opkg.
root@OpenWrt:~# opkg update
Downloading http://mightyohm.com/files/kamikaze-2.4/packages/mipsel/Packages.gz
wget: bad address 'mightyohm.com'
Signiture check for snapshots skipped because GPG support was not enabled in this build
Collected errors:
* opkg_download: ERROR: Command failed with return value 1: `wget --passive-ftp -P /tmp/opkg-JPeQJf http://mightyohm.com/files/kamikaze-2.4/packages/mipsel/Packages.gz'
Looking further, you place the wl0 device in the "wlan" network, but there is no definition for "wlan" in /etc/config/network. You need to add something about wlan there, such as (in my case):
Neither. I simply installed the Backfire release of OpenWrt and configured the whole thing myself. But I do use it in the same way as a music player which plays music from the local network or from an internet stream.
WPA2-CCMP might be the problem. Can you change your wireless network to WPA2-AES instead?
I have had problems getting OpenWRT to connect to certain WPA/WPA2 configurations. WEP pretty much always works. I use WPA2-AES here and it seems to work ok, but I had to put single quotes around my network key because it has some special (non-alphanumeric) characters in it.
And I think you need to enclose your SSID in single quotes ie. 'My SSID has spaces' or change your SSID to something easier (no spaces or special characters).
