hi,
with the radio wifi and lcd
when i go with usbtiny and avr
led green ok lcd backlight ok
i have a atmega 328 from spark
avrdude :AVR device initialized and ready to accept instructions.
reading :device signature =0x1e9406 avrdude. Expected signature for ATmega328is 1E950F: Double check chip or use -F to override this check.
What can i do ?
FA
double check chip or -F to override tihs check
Re: double check chip or -F to override tihs check
FA,
the make file has the chip type hard coded. It is expecting a ATmega168 but you are using a 328. You need to adjust the make file. Look for a line like “avrdude ... –p Atmega168 …” and change the “ATmega168” to the correct value for ATmega368 (you have to look up what this will be). Regards, Michael
thanks ,all is ok now
What is strange is that the error message you posted shows that avrdude read a signature of 0x1e9406, which would seem to indicate that an ATmega168A was found on the target board.
Also, I'm not sure how avrdude knew that the "Expected signature for ATmega328 is 1E950F" without already being told that it was supposed to program a 328P. Something doesn't make sense.
Regardless, I'm glad you have it fixed.
