Adding shoutCAST .pls
Silent-Hunter
Post by Silent-Hunter »
How can I do this? When I put the URL to the .pls in, and play it, nothing happens.
Re: Adding shoutCAST .pls
Post by jeroen94704 »
Does your version of MPD support streaming? To find out, execute "mpd --version" on the command line. This will give you a list of supported formats and outputs.
What does this say?
NelsonPJ
Post by NelsonPJ »
Have you looked at this thread? ilinux wrote a script to parse PLS files:
viewtopic.php?f=2&t=130
Silent-Hunter
I figured it out. If you open the PLS file in a text editor, you can see the stream URL inside. Then you just put that into "mpc add".
ilinux
Post by ilinux »
You can use this script that comes here for extract and add automatically
http://www.sandrofabbro.com/wrtradio/scripts/
For add to your firmware read here:
viewtopic.php?f=2&t=130#p592
