Hey guys!
Let me start off by thanking Jeff for taking the time to post this project. I have been having a lot of fun setting it up and messing around with the router! I have deviated from his original plans and have used a Boarduino to control my parallel LCD. I am running into a problem, however, when receiving playlist info - the LCD spits out all the info on 1 line, then when it reaches 40 characters, it pumps the remaining info on the second line. I've been stuck on this for 3 weeks and I've tried looking everywhere for an answer to this question;
Does the serial output a carriage return character, and if so, how can I read it as a carriage return?
If you'd like, I'll paste my sketch up so you can have a better idea of what I'm working with. I'll also paste it once I get it working, for all the others who have opted for the Arduino setup.
Thanks for any help you can provide!
Question about LCD interfacing
Re: Question about LCD interfacing
Evil Potato -
The serial data doesn't contain formatting specific to the LCD. The serial output of the router is something like:
Title: Some Artist - Some Song Name
Each line has a newline character at the end, but it's up to the microcontroller driving the LCD display to figure out how to best display the data. On my ATmega I have some code that figures out what will fit on the display, and if the line is longer than the display width, it tries to put the newline in a semi-intelligent place that avoids wrapping words. If the line is really long, ie. > 2x display width, then it prints beyond the visible area of the LCD and uses the LCD scroll function to shift the display left and right so you can see the whole line, as shown in the video on my blog.
Does that make sense? Unfortunately it means more work for you but I don't think its good to put formatting into the serial data in case different people have different display sizes, etc.
Hey Guys;
I've made some headway on the arduino interface for your display script. I am still running into a problem while trying to display to text, however. My code is posted below, (I know it may be messy - I'm still learning )
I'm trying to defeat to 40 character max by re-writing the data strings grabbed from each line of the serial output to something that is 16 characters at a time, then clearing the LCD cache and printing the new strings for a scroll 'effect'. For some reason, the lcd doesn't display any text input [edit]whatsoever[/edit] it displays the welcome string.
Any thoughts?
#include <LCD4Bit.h>
#include <WString.h>
#define CMD_NOWRAP 0x44
//#define CMD_SHIFTLEFT 0x18
LCD4Bit lcd = LCD4Bit(2); // set the number of Displays lines
char data1;
String topData;
String topFir;
char data2;
String botData;
String botFir;
String welcome= " -=[::WiFi::]=-";
void setup() {
lcd.commandWrite(CMD_NOWRAP);
Serial.begin(9600); // set the baudrate
lcd.init(); // initialize
lcd.clear(); // clear the screen
lcd.printIn(welcome); // display something
void loop()
//lcd.clear();
//lcd.printIn(" waiting ");
int i=0;
int o=0;
if (Serial.available()) { //something's coming
delay(900); //wait for it
lcd.clear(); //clear the old junk
while (Serial.available()) {
data1 = Serial.read(); //import a letter at a time
topData.append(data1);
if (data1 == '\n'){ //encounters a carriage return
while (Serial.available() && data2!='\n') { //break if I get a \n on the second line
data2 = Serial.read(); //save line 2 data
botData.append(data2);
o++; //get the next letter
i++; //get the next letter
//int p=0; //init stuff
int t=0;
int b=0;
int big=0;
int count=0;
if (i>o){ //find out what string is longest
big=i;
else {
big=o;
if (i!=0){ //if data received through Serial input
for(count=0;count<big;count++){ //do this until the end of the longest string
for(t=0;t<15;t++){ //set the temp display lines up 16 chars at a time
topFir.setCharAt(t, topData.charAt(t)); //top line
botFir.setCharAt(t, botData.charAt(t)); //bottom line
lcd.cursorTo(1,0); //start from 1
lcd.printIn(topFir); //display most recent 16 chars
lcd.cursorTo(2,0); //jump to 2
lcd.printIn(botFir); //""
for(t=0;t<big;t++){ //time to shift the input data over 1 char at a time
topData.setCharAt(t, topData.charAt(t+1));
botData.setCharAt(t, botData.charAt(t+1));
delay(500); //psuedo-scroll
lcd.clear(); //don't blink!
delay(500); //probably don't need this
topData=0; //clear cache out
botData=0;
topFir=0;
botFir=0;
i=0;
o=0;
t=0;
count=0;
Any thoughts?
Did you ever get your Arduino working with this project? Just yesterday I got my router playing music with mpc/mpd (woo hoo!) and last winter I successfully interfaced a 16x2 LCD to an Arduino and managed to display "Hello World". I haven't linked the two together yet, so I was wondering if somebody's already got code they could share. From reading your post above, it sounds like the code you posted didn't quite work? Did you ever figure it out?
