Here are my notes - this is for Kamikaze 8.09, slightly different than what I used for the original Wifi Radio project. I compiled the packages myself and had them in a separate repository that I pointed opkg to.
Hacking the WL-520gU Wireless Router - Demo
JSK 4/11/09
Step 0 - Flash the factory firmware into the router. Verify operation,
1. Connect ethernet, USB-serial to the macbook and router.
2. Open Zterm.
3. Apply power to the router. Show boot messages on Zterm,
4. Open http://192.168.1.1 and show factory firmware is running.
5. Power off. Press reset. Power on. Show tftp prompts.
6. tftp the new image to the router
cd ~/openwrt/kamikaze-8.09
tftp
trace
mode binary
connect 192.168.1.1
put openwrt-brcm-2.4-squashfs.trx
~/openwrt/kamikaze-8.09/openwrt-brcm-2.4-squashfs.trx
wait until programming is complete.
7. Power cycle router.
8. Wait for flash format to complete. Hit enter.
9. Set passwd
10. Edit /etc/opkg.conf to point to:
src/gz snapshots http://192.168.1.185/~jkeyzer/kamikaze-8.09/
11. Run opkg update. Confirm that it worked.
12. opkg install kmod-usb-ohci kmod-usb-audio kmod-usb-storage kmod-
fs-vfat
13. reboot
13. Plug in USB hub with usb-audio and thumb drive
14. mkdir /mnt/usb
15. mount /dev/scsi/host0/bus0/target0/lun0/part1 /mnt/usb
16. cd /mnt/usb ; ls
17. opkg update
18. opkg install libpthread tinysid
19. tinysid ./Resolution.sid
if I get that far...
20. edit /etc/config/wireless to point to wlan
21. opkg install mpc mpd
22. cd ~
23. mkdir music
24. mkdir .mpd
25. mkdir .mpd/playlists
26. vi /etc/mpd.conf
27. mpd
28. mpc add http://relay3.slayradio.org:8000/
29. mpc play
