Example config files (look here if you are having problems)
Post by mightyohm » Fri Mar 11, 2011 11:07 am
Originally posted here:
http://www.mightyohm.com/forum/viewtopic.php?f=2&t=275
Here are the config files I am using, for reference:
/etc/config/wireless
config wifi-device  wl0
	option type     broadcom
	option channel  5
	option device   wl0
	option network	wan
	option mode     sta
	option ssid     MYSSID
	option encryption wep
	option key MYWEPKEY
/etc/config/network
	option vlan0	"1 2 3 4 5*"
	option vlan1	"0 5"
	option ifname	"lo"
	option proto	static
	option ipaddr	127.0.0.1
	option netmask	255.0.0.0
	#option type 	bridge
	option ifname	"eth0.0"
	option proto	static
	option ipaddr	192.168.1.1
	option netmask	255.255.255.0
config interface	wan
	option ifname	"eth0.1"
	option proto	dhcp
/etc/config/firewall
config defaults
	option syn_flood	1
	option input		ACCEPT
	option output		ACCEPT
	option forward		REJECT
config zone
	option name		lan
	option input	ACCEPT
config zone
	option name		wan
	option input	ACCEPT
	option masq		1
config forwarding
	option src      lan
	option dest     wan
### EXAMPLE CONFIG SECTIONS
# do not allow a specific ip to access wan
#config rule
#	option src		lan
#	option src_ip	192.168.45.2
#	option dest		wan
#	option proto	tcp
#	option target	REJECT
# block a specific mac on wan
#config rule
#	option dest		wan
#	option src_mac	00:11:22:33:44:66
# block incoming ICMP traffic on a zone
#config rule
#	option src		lan
#	option proto	ICMP
#	option target	DROP
# port redirect port coming in on wan to lan
#config redirect
#	option src			wan
#	option src_dport	80
#	option dest			lan
#	option dest_ip		192.168.16.235
#	option dest_port	80
#	option proto		tcp
# include a file with users custom iptables rules
#config include
#	option path /etc/firewall.user
### FULL CONFIG SECTIONS
#config rule
#	option src		lan
#	option src_mac	00:11:22:33:44:55
#	option src_port	80
#	option dest		wan
#	option dest_ip	194.25.2.129
#	option dest_port	120
#	option proto	tcp
#config redirect
#	option src		lan
#	option src_port		1024
#	option proto	tcp
Nurek_bagieNNy
Re: Example config files (look here if you are having probl
Post by Nurek_bagieNNy » Sat Sep 22, 2012 5:35 am
content of /etc/init.d/mpd would be very useful :)
Post by mightyohm » Sat Sep 22, 2012 10:42 pm
This is /etc/init.d/mpd:
#!/bin/sh /etc/rc.common
# Copyright (C) 2007 OpenWrt.org
START=93
start() {
	#create mpd directories
	md=`grep music_directory /etc/mpd.conf | cut -d "\"" -f 2 | sed "s/~/\/root/g"`
	if [ ! -d $md ]; then
		mkdir -p $md
	fi
	pld=`grep playlist_directory /etc/mpd.conf | cut -d "\"" -f 2 | sed "s/~/\/root/g"`
	if [ ! -d $pld ]; then
		mkdir -p $pld
	fi
	#create mpd db
        /usr/bin/mpd --stdout --create-db
	#optional export for mpc
        #export MPD_HOST=127.0.0.1
	#start mpd
        /usr/bin/mpd
	#generate playlist and start to play
        /usr/bin/mpc listall | /usr/bin/mpc add -
        /usr/bin/mpc play
	/usr/bin/mpc repeat
stop() {
        killall mpd
cgchris99
Re: Example config files (look here if you are having problems)
Post by cgchris99 » Tue Apr 18, 2017 3:22 pm
Is that code w10 or wl0. Is that #1 or letter L?
Post by mightyohm » Tue Apr 18, 2017 5:06 pm
lowercase letter 'L'
wl0
