Any chance for a board to be produced?
Re: Any chance for a board to be produced?
Postby mightyohm » Fri Nov 06, 2009 12:17 pm
You should be able to attach it to your post on the forums here. Click "upload attachment" below your message and see if you can upload the file there.
flexopete
Postby flexopete » Sat Nov 07, 2009 8:07 am
I tried it again, but I get the message:
The extension pdf is not allowed
The extension brd is not allowed
Peter
Postby mightyohm » Sat Nov 07, 2009 12:15 pm
Should be fixed now. Sorry about that! :oops:
flexopete
Postby flexopete » Sat Nov 07, 2009 1:08 pm
Here the files
MEGA168-DISPLAY.pdf
(13.21 KiB) Downloaded 708 times
MEGA168-DISPLAY.brd
(22.26 KiB) Downloaded 610 times
Postby mightyohm » Sat Nov 07, 2009 2:03 pm
Do you have a .sch file you would like to share as well, or at least a png of the schematic?
flexopete
Postby flexopete » Sun Nov 08, 2009 7:08 am
I don't have a .sch file. I used your schematic and added only a reset pullup
and a 2nd 0.1uF.
Peter
horace
Postby horace » Sun Nov 08, 2009 9:32 am
Hmm.. something seems to be wrong with this PCB.
All SMDs are at the Top layer but their connections at the Buttom layer...
Postby mightyohm » Mon Nov 09, 2009 11:24 pm
horace wrote:Hmm.. something seems to be wrong with this PCB.
I see the same issue here!
mred
Postby mred » Sat Jan 07, 2012 1:38 am
mightyohm wrote:Possibly after the Maker Faire, later this month. There was some talk of a kit being produced but it hasn't materialized yet, so I may go off on my own and make a PCB for the AVR/LCD circuit.
I'm guessing that this hasn't happened? What sort of cost would there be to making such a thing?
I have my radio built now, I'll try to take some photos soon. I used an old surround sound amp with a remote for adjusting the volume, and the ASUS WL-520GU. I then built a custom box that holds the subwoofer, the circuit boards, the power wall warts (which I stripped out of their casing and hard wired to a plug) and the front left and right speakers. Still to do is add the LCD screen, and some connectors on the back for an AUX in and extra speaker outputs. The ultimate plan is to have this set up in the loungeroom, with speaker leads heading outside to an outdoor entertaining area, and being controlled from an Android MPD client.
So I'm quite interested in a PCB for the disply side of things, as this will be much easier to keep in the box and still be somewhat tidy :D
Cheers,
Ed
Postby jeroen94704 » Wed Jan 11, 2012 11:15 pm
I am in the process of developing a PCB layout for this project. If anyone is interested, I'd be willing to share it here (including the .sch). Maybe if enough people are interested in a PCB we could order a batch together.
