Any chance for a board to be produced?
Re: Any chance for a board to be produced?
You should be able to attach it to your post on the forums here. Click "upload attachment" below your message and see if you can upload the file there.
I tried it again, but I get the message:
The extension pdf is not allowed
The extension brd is not allowed
Peter
Peter
Should be fixed now. Sorry about that!
Here the files
- Attachments
- MEGA168-DISPLAY.pdf
- (13.21 KiB) Downloaded 1354 times
- MEGA168-DISPLAY.brd
- (22.26 KiB) Downloaded 1233 times
Do you have a .sch file you would like to share as well, or at least a png of the schematic?
I don't have a .sch file. I used your schematic and added only a reset pullup
and a 2nd 0.1uF.
Peter
and a 2nd 0.1uF.
Peter
Hmm.. something seems to be wrong with this PCB.
All SMDs are at the Top layer but their connections at the Buttom layer...
I see the same issue here!horace wrote:Hmm.. something seems to be wrong with this PCB.
I'm guessing that this hasn't happened? What sort of cost would there be to making such a thing?mightyohm wrote:Possibly after the Maker Faire, later this month. There was some talk of a kit being produced but it hasn't materialized yet, so I may go off on my own and make a PCB for the AVR/LCD circuit.
I have my radio built now, I'll try to take some photos soon. I used an old surround sound amp with a remote for adjusting the volume, and the ASUS WL-520GU. I then built a custom box that holds the subwoofer, the circuit boards, the power wall warts (which I stripped out of their casing and hard wired to a plug) and the front left and right speakers. Still to do is add the LCD screen, and some connectors on the back for an AUX in and extra speaker outputs. The ultimate plan is to have this set up in the loungeroom, with speaker leads heading outside to an outdoor entertaining area, and being controlled from an Android MPD client.
So I'm quite interested in a PCB for the disply side of things, as this will be much easier to keep in the box and still be somewhat tidy
Cheers,
Ed
I am in the process of developing a PCB layout for this project. If anyone is interested, I'd be willing to share it here (including the .sch). Maybe if enough people are interested in a PCB we could order a batch together.
