After following the instructions for step 8 changes to /etc/config/network (including lan/wan correction in step 9), I can no longer connect to the internet. When I "ping www.google.com", I get "ping: bad address 'www.google.com'". The "Air" light on the Asus is on (although dim).
When I undo the changes to /etc/config/network and wireless, I get internet connectivity again. I changed my home wireless router to 192.168.24.xxx to avoid conflicts. With this configuration I can access internet (ping google, wget from mightyohm.com, etc). When I make the changes in Steps 8/9, I no longer can access the outside world.
Please help!
Any help is appreciated.
Please help: Stuck on part 8 (no more internet)
Re: Please help: Stuck on part 8 (no more internet)
Hello!!
Can you post your before and after (working and not-working) /etc/config/network and /etc/config/wireless files? Did you change /etc/config/firewall also?
Files in working configuration (before steps 8/9):
network:
wireless:
firewall:
root@OpenWrt:~# ping http://www.mightyohm.com
PING http://www.mightyohm.com (75.125.121.238): 56 data bytes
64 bytes from 75.125.121.238: seq=0 ttl=48 time=64.050 ms
64 bytes from 75.125.121.238: seq=1 ttl=48 time=46.390 ms
64 bytes from 75.125.121.238: seq=2 ttl=48 time=69.734 ms
64 bytes from 75.125.121.238: seq=3 ttl=48 time=52.942 ms
Not working config (only changes are "LAN configuration" and wireless lan to wan, Steps 8/9)
network
wireless
No changes to firewall.
As of this documenting/testing/, home network is on 192.168.1.xxx
ping: bad address 'www.mightyohm.com'
Do I need to change the 'config forwarding' in firewall? Note that in this configuration I am able to Telnet to the router with a direct RJ45 cable from my latop to the router, as well as via the serial interface (FTDI cable).
Any ideas on why the last config does not work is appreciated.
network:
option vlan0 "1 2 3 4 5*"
option vlan1 "0 5"
option ifname "lo"
option proto static
option ipaddr 127.0.0.1
option netmask 255.0.0.0
option type bridge
option ifname "eth0.0"
option proto dhcp
#option ipaddr 192.168.1.1
#option netmask 255.255.255.0
config interface wan
option ifname "eth0.1"
option proto dhcp
config wifi-device wl0
option type broadcom
option channel 6 # channel of wireless network
# option disabled 1
option device wl0
option network lan
option mode sta # configures router to connect to network
option ssid MyNetwork # SSID of network
option encryption psk2
option key MyPass
config defaults
option syn_flood 1
option input ACCEPT
option output ACCEPT
option forward REJECT
config zone
option name lan
option input ACCEPT
config zone
option name wan
option input ACCEPT
option masq 1
config forwarding
option src lan
option dest wan
network
option vlan1 "0 5"
option ifname "lo"
option proto static
#option type bridge
option proto static
option proto dhcp
# option disabled 1
option device wl0
option network wan
option key MyPass
Thanks dddesign for your reply!
But I couldn't get that to work either.
After spending many hours trying different options/combinations, this is what I got to work:
network file:
The trick for me is to have the router lan address on a different subnet than my home network (ok, I can kinda see how that might be needed), and making the wan "option type bridge". I must do BOTH. Either of the above changes alone don't work.
Is that right? I have seen no one else who needed to make the wan 'bridge'. That is the only way it seems to connect to my wifi network (by monitoring the "DHCP Active IP Table" on my home network wifi router). Is this bad? Could it mess up something?
network file:
option vlan1 "0 5"
option ifname "lo"
option proto static
# option type bridge
option proto static
option ipaddr 192.168.2.1
option type bridge
option proto dhcp
