AP client, used bridged mode or DMZ?
hub.martin
Post by hub.martin »
Hello, I would like to configure my OpenWRT to configuration explained balow. I read lot pages on OpenWRT wiki but I'm not sure if I have to configure VLANs or use DMZ.. It's ok if anyone just shows me the right direction. I configured my router perfectly and I don't want to experiment and mess up something with network configuration...
I'm using network configuration from this site. The router connects and starts playing music after boot over a wifi or over ethernet cable (if there's no wifi) on ports WAN, LAN1-LAN5. What I want is to configure some port to be bridged (I hope that's the right term) with wifi. Simply I want to connect my PC to let's say LAN4 port and use my network over router which is connected over WiFi. I prefer no NAT there.. if it's possible.
There's my network configuration.
Thank you
        option vlan0    "1 2 3 4 5*"
        option vlan1    "0 5"
        option ifname   "lo"
        option proto    static
        option ipaddr   127.0.0.1
        option netmask  255.0.0.0
        option type     bridge
        option ifname   "eth0.0"
        option  proto   dhcp
config interface        wan
        option ifname   "eth0.1"
        option proto    dhcp
hub.martin
Re: AP client, used bridged mode or DMZ?
I made some progress myself. I changed option-network in wifi configuration from "wan" to "lan":
config wifi-device  wl0
        option type     broadcom
        option channel  1
        option disabled 0
        option device   wl0
        option network  lan
        option mode     sta
        option ssid     hub_indoor
        option encryption none
With this configuration, when the router is connected to my AP, I can connect my laptop po LAN1-4 and I get DHCP adress from my AP and it works as I wanted.
But when I connect the router to my network only by WAN port, radio plays but I'm not able to obtain any IP address over DHCP when my laptop is connected to LAN1-4.
I'm quite happy now. But I'm courious why it doesn't work by WAN...
