Tuning only
tobarix
Tuning only
Post by tobarix »
I only want the tuning feature (no space to accommodate lcd in my vintage radio)
Does anybody know wether you have to install the lcd to get the AVR going or can I just hookup the potmeter? After successfully flashing the ATmega328P on my Arduino Pro Mini board and wire the tuning hookup, stations won't change.
Re: Tuning only
Looking at the source code, it looks like it will deadlock if the lcd is not attached.
As far as I can see, you can prevent this by disabling IO-mode.
Open lcd.h and change line 70 to read (i.e. change the '1' to a '0')
#define LCD_IO_MODE      0
tobarix
Re: Tuning only
Post by tobarix »
Thanks Gerben, radio is working fine now. You are right it needs LCD hookup to get it going. I will change to program following your suggestions and see what happens then.
