Flashing ATmega328p fails
tobarix
Post by tobarix »
Now I am really lost. I Tried to flash my ATmega328P with this result:
iMac-van-Fred:temp FRED$ make flash
avrdude -c usbtiny -p atmega168 -U flash:w:main.hex:i
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.01s
avrdude: Device signature = 0x1e950f
avrdude: Expected signature for ATmega168 is 1E 94 06
Double check chip, or use -F to override this check.
avrdude done. Thank you.
Can I override this check and how do I do that?
I am not a programmer, I just follow the Mightyohm instructions.
tobarix
Re: Flashing ATmega328p fails
Post by tobarix »
Problem solved. I just changed atmega168 into atmega328p in the flash command.
irag
Post by irag »
Thanks, baud rates are OK. It is not garbage. It repeats the same code and after a station change it repeats a new code. I guess it needs translation. Maybe the Sitecom adapter meshes things up.
irag
