Precomplied MightyOhm OpenWRT image won't install on router
rcr
Post by rcr »
Hello everyone! Used your tutorial and tried to install precompiled MightyOhm OpenWRT image (http://mightyohm.com/files/kamikaze-2.4 ... uashfs.trx) on my newly bought Asus WL-520GU. After uploading the firmware router doesn't start. Backfire 10.03 (http://downloads.openwrt.org/backfire/1 ... uashfs.trx) installed correctly and as mentioned in one of previous topics I've failed on mpd installation with insufficient disk space. Maybe I've downloaded the wrong Kamikaze firmware? Is there any other way to install everything right on Backfire without usb hub and flash drive?
Re: Precomplied MightyOhm OpenWRT image won't install on rou
No. There is just not enough room. You could try mouting a NFS volume for extra space, but I thinks the HUB and thumbdrive solutions would be a whole lot easier.
But try downloading Jeffs image again. Maybe something went wrong while downloading resulting in a corrupted image. Try running md5sum over the old an the newly downloaded file to see if there is any difference. The file I used is on a different computer, so I can't send you my md5sum.
