Page 2 of 2
Re: interface.sh not starting at boot
Posted: Thu May 24, 2012 3:14 am
by jeroen94704
Are you maybe changing anything else in the network configuration. Keep in mind that the wifi interface can either be client or access point, but not both at once. How are you connecting your PC to the router? Using a network cable or wirelessly? How does the router connect to the internet? Using a cable, or wirelessly? What does your network configuration on the router look like?
While I've learned to never say "impossible" when it comes to computers, it strikes me as unlikely the interface.sh script is responsible for this problem, since it only interacts with the serial port, not the network interfaces.
Posted: Thu May 24, 2012 5:42 pm
by janur55
okay,,thanks for reply
i feel strange why if i make it run at boot i can't browse via my pc...i connected via cable to my asus lan port
but if i make chmod ugo-x /etc/init.d/AVR then reboot...i can browse via PC,, so weird
i was change the START command from /etc/init.d/AVR from 40,10 but it actually not show the change..so i make it default again
here my configuration
/etc/config/network
option vlan0 "1 2 3 4 5*"
option vlan1 "0 5"
option ifname "lo"
option proto static
option ipaddr 127.0.0.1
option netmask 255.0.0.0
option type bridge
option ifname "eth0.0"
option proto static
option ipaddr 192.168.0.1
option netmask 255.255.255.0
config interface wan
option ifname "eth0.1"
option proto dhcp
/etc/config/wireless
config wifi-device wl0
option type broadcom
option channel 5
# option disabled 1
option device wl0
option network wan
option mode sta
option ssid "TESTING1"
option encryption none
/etc/config/firewall
config defaults
option syn_flood 1
option input ACCEPT
option output ACCEPT
option forward REJECT
config zone
option name lan
option input ACCEPT
config zone
option name wan
option input ACCEPT
option masq 1
config forwarding
option src lan
option dest wan
### EXAMPLE CONFIG SECTIONS
# do not allow a specific ip to access wan
#config rule
# option src lan
# option src_ip 192.168.45.2
# option dest wan
# option proto tcp
# option target REJECT
# block a specific mac on wan
#config rule
# option dest wan
# option src_mac 00:11:22:33:44:66
# block incoming ICMP traffic on a zone
#config rule
# option src lan
# option proto ICMP
# option target DROP
# port redirect port coming in on wan to lan
#config redirect
# option src wan
# option src_dport 80
# option dest lan
# option dest_ip 192.168.16.235
# option dest_port 80
# option proto tcp
# include a file with users custom iptables rules
#config include
# option path /etc/firewall.user
### FULL CONFIG SECTIONS
#config rule
# option src lan
# option src_mac 00:11:22:33:44:55
# option src_port 80
# option dest wan
# option dest_ip 194.25.2.129
# option dest_port 120
# option proto tcp
#config redirect
# option src lan
# option src_port 1024
# option proto tcp
thanks for your help
