Q: External power, 5v or 3v, current?
Stephanie
Post by Stephanie »
I'm looking to assemble this kit tonight (found it at Adafruit.com) and have some questions about powering it externally rather than using AAA batteries.
I plan to connect the geiger counter to an Arduino mega which is running at 5vdc. Ideally I'd just tie the geiger counter's + and - lines to Vcc and Ground on the Arduino, but I wanted to confirm first if that would mess things up on the HV section of the geiger counter.
If running it at 5v is a Bad Idea, I do have a 3v linear regulator that I could drop in, but my regulator is only rated up to about 250 mA and I don't know if that is enough. Do you know what sort of current the geiger counter draws?
Thank you!
Re: Q: External power, 5v or 3v, current?
The kit runs at 3V and about 10mA (a little more with the LED on). 250mA is more than enough.
It should be possible to run everything at 5V. I would recommend increasing R6 to around 2.2K to avoid overstressing the HV switching transistor Q1, and increasing R11 to 330 Ohms to avoid blowing the LED.
Stephanie
Post by Stephanie »
Wow thank you for such a fast reply!
10 mA is great news, I imagine this must run for quite a long time on a pair of AAA batteries.
I think I'll put the kit together as intended and then just employ the voltage regulator when it's running from the external 5v supply.
Cheers!
wbp
Post by wbp »
The Mega has a 3.3 V supply which is rated at 50 ma. If you don't have anything else using it, that's more than enough to run the geiger counter. Why not just use that?
William
